So I have a DX hatch from 96'. It only has 37k miles on it and I plan on doing suspension modification first (coils, control arms, sway bars, subframe brace, etc..) but I'm pretty new and want to push more than 107hp, after some research I found the mini me swap with the y8 for about a 20hp gain but also found that you can turbo the stock block and get around 190-200hp without even touching the internals. My goal would be around 200hp but semi-reliable as this is sort of my daily. So I have a few questions, how would I get to ~190hp with the y8 head? Which would be cheaper? (I'm in HS) Which would need more mechanical knowledge?
If this has been asked before sorry, any links to threads or informational documents about my car/engine are appreciated and thank you in advance, I'm pretty confused right now.
