Baer 13.1” Big Brake kit (www.extrememotorsports.com)
* Stainless steel brake lines front and rear
Suspension
* Ground Control Coil-overs with Koni Yellow adjustable shocks
Wheels
* 17” Black Rota SubZeros
* Potenza S03 - 225-45-17
Exhaust
* 3" Stainless 02 Dump
* 3” Cat Back Exhaust – Apex World Sport
Intake
* K&N Filter
* 3” Dejon Tool Intake
* 1G BOV
* Greddy FMIC
* Water injection system activated at 10 PSI
Turbo
* AGP L2R Ball Bearing Turbo
Fuel
* 660 Injectors
* 6AN Braided fuel lines from Pump to fuel rail and fuel return line
* SX Fuel Pressure Regulator
* SX Fuel Filter
* Supra Fuel Pump and Fuel Pump rewire
Transmission/Clutch
* Stock 95 tranny
* Stock 6-bolt flywheel
* ACT 2600
Cooling system
* Fluidyne Aluminum Radiator
*FAL slim dual fans
Boost Control
* Blitz Dual SBC Spec R
Gauges
* 0 – 30 VDO Boost Gauge
* Extreme Air/Fuel Meter
*PLX wideband wired to dataloge through DSM link.
Stereo System
* Rockford Phosgate in dash MP3 Player
* 8” Bass Tube
* Boston acoustic speakers in stock locations
Engine Management
* DSM Link
Engine
* 1G Six Bolt engine from a 92 Eclipse
* 92 Big Rods with 95 Pistons
* Mitsu Metal Head Gasket
* Battery Relocated to Trunk
*ARP head studs
Ignition
* NGK BPR7ES Plugs
* 8.5mm Wires
*Optima RED top battery
Will trade for a Turbo Eg...
Suspension
Wheels
Exhaust
Intake
* K&N Filter
* 1G BOV
* Greddy FMIC
Turbo
Fuel
* 660 Injectors
* SX Fuel Filter
Transmission/Clutch
* Stock 95 tranny
* ACT 2600
Cooling system
*FAL slim dual fans
Boost Control
Gauges
Stereo System
* 8” Bass Tube
Engine Management
* DSM Link
Engine
*ARP head studs
Ignition
* NGK BPR7ES Plugs
* 8.5mm Wires
